@Scorpio_ny Both look fantastic. Well done!
Oct 22, 2025
S
Scorpio_ny
Hi @JDW, First thank you for the pictures. I remembered that I had a flashed video card for my G4 cube that had the same type of VGA...
Oct 22, 2025
Eric's Apple Network Server 700 tinker log
Also useful would be a dump of the PCI registers of all the PCI devices since dump-device-tree shows only some of them. Here's a dropbox...
Oct 22, 2025
O
omega
I did new tests and the color matches in my opinion. The speed is worse. With 16 set the real speed is 5.333. With 18 it is 6 and with...
Oct 22, 2025
patters
Flashing Prism2 wifi cards for WPA2 compatibility
Amiga
I went down the rabbit hole of getting WPA2 connectivity on my Amiga 600. It's much slower (around 0.1x) than a wired NIC, but it's a...
Oct 22, 2025
eyeidea
@0dan0 not sure what happened but I did a roll of reg 8 and got 5fps and really low data rate ....
Oct 22, 2025
eyeidea
@0dan0 I just ran V7.0 on Type C without issue. Can you give me a quick refresh on settings ... is this correct? WB: 0.0 Sharp: -1...
Oct 22, 2025
