kefkafloyd
LC520 Overclock
Sorry for not clarifying on Speedometer, the versions I used were Speedometer 3.2.3 and 4.0.2 (and I labeled them 3 and 4 as you...
Oct 24, 2025
Faster Baud and More Serial Ports (CSI Hurdler, SerialDMA, QuadraLink)
Almost. You just need to put a null modem adapter between the two cables. Because you are a 128K fan:
Oct 24, 2025
PicoMicroMac v2
Because there is not a serial port on our tiny little friend, I thought I would try a hack. From Adafruit, I ordered three parts ($20...
Oct 24, 2025
Connect ADC monitor to HDMI source
@fehervaria Very odd I missed seeing your thread (started back in 2021) until today! Wow! So the interface shown in your opening post...
Oct 24, 2025
It seems than that it is exFAT, not the media size that is the issue. These units do not support files greater than 4GB, so formatting...
Oct 24, 2025
Comparison between Babyface and TT Design PSUs for SE/30?
I have not. I have only reviewed the BabyFace PSU. I believe that TT Design version came out AFTER the BabyFace was released. Not...
Oct 24, 2025
So... We should the following? 1. Connect one end of a normal Mac serial cable to the vintage Mac. 2. Connect the other end to a...
Oct 24, 2025
LC520 Overclock
And here are the MacBench 3.0 results, showing that CPU/FPU are essentially the same for your board and mine, but your board still shows...
Oct 24, 2025
pax
Compact Macs
Has anyone done a comparison between the Babyface and TT Design PSUs for SE/30? I’m looking to swap out an original PSU...
Oct 24, 2025
