ESM-NL
SCSI being wonky
Could be several things. Have you messured the 5V rail? Could be that the BlueSCSI will work with if you connect the molex connector...
Oct 28, 2025
D
dougg3
Yeah, if the ROM is accessed after OF is up, it would be tricky to add a switch because it's game over after the switch is flipped to...
Oct 27, 2025
RolandJuno
Pocket(CHIP) Macintosh
3D Printing
A few years ago, I compiled MiniVMac on the PocketCHIP enabling AppleTalk via LToUDP. Since then, the PocketCHIP has made a handy...
Oct 27, 2025
S
Scout
6100 Schematic?
Thanks. Not sure the boards are that similar. The pin goes to a via and I have not been able to trace yet.
Oct 27, 2025
Should perform a test in DPPC to see if anything (exception handlers?) in ROM is accessed after Open Firmware is set-up. Can do a copy...
Oct 27, 2025
6100 Schematic?
The closest thing would be the 8100 schematics. https://www.macdat.net/repair/apple_schematics.html The 6100 and 6100 Enhanced...
Oct 27, 2025
I
iigs123
Assemble a TransWarp GS CPU cable?
If you don't want to try to make it, you can buy it from ReactiveMicro...
Oct 27, 2025
N
NJRoadfan
The pinout of that cable is weird. The Bill Shuff cable I have has all pairs twisted (reversed) at the TWGS end of the cable. The pinout...
Oct 27, 2025
Jockelill
Yes, is the short answer, but it’s a little bit more complicated than that. Essentially the ISP that @zigzagjoe has created does this...
Oct 27, 2025
SuperSVGA
As long as it's running fully from RAM at the point that you switch ROMs it would work fine.
Oct 27, 2025
S
sam256
Port of Continuum (classic mac game) to web
just go straight to level 9 :)
Oct 27, 2025
