Gentlemen, There are three points of concern: 1. The LCD used by @ArjenCNX measures 8 inches diagonal. The (fake?) Eyoyo I bought...
Oct 29, 2025
A
ArjenCNX
Oct 29, 2025
A
ArjenCNX
Resin would require a very large printer to make, not easy to find. but clear PETG would be an option for sure, and it would hide enough...
Oct 29, 2025
This screen, mounted on a clear IIc case, with the 3d parts printed in clear resin would be incredible looking. @JDW, I feel like it...
Oct 29, 2025
BeOS Install
I thought I included the BeOSTools image in that macintosh garden upload. But it seems the garden is down at the moment...
Oct 29, 2025
lundpk
BeOS Install
I read something about an OS Chooser extension being installed - but I am not sure it was installed automatically. Might need to...
Oct 29, 2025
BeOS Install
I didn’t think you would be able to see the BeOS drive from in MacOS. You should run the BeOS launcher to restart and mount the BeOS...
Oct 29, 2025
T
Macintosh connector part numbers
That's them. They still have the 64 pin SIMM socket for less than $2. However, the Quadra connector, 8817-140-170LH no longer has a...
Oct 29, 2025
lundpk
BeOS Install
I just finished retro rebuild of Power Mac 7600 with BlueSCSI and am workign through my issues of getting the Mac to see the BeOS hard...
Oct 28, 2025
C2 Capacitor Replacement on Mac 512k Analog Board Smoking
You haven’t measured voltage across the legs of the smoking capacitor, but you should because it must be over voltage that is causing it...
Oct 28, 2025
N
NJRoadfan
Assemble a TransWarp GS CPU cable?
As stated on several sites, the wire pairs need to be flipped similar to this example...
Oct 28, 2025
