I also have Plamen's IIc to VGA adapter, and since my Eyoyo has VGA as well as HDMI, I could compare it with the A2DVI interface. The...
Oct 29, 2025
wskjinfen
C2 Capacitor Replacement on Mac 512k Analog Board Smoking
I suggest you first check if CR1 is working properly. Touch the blue capacitor connected to the flyback 4-pin connector to see if it...
Oct 29, 2025
wskjinfen
A Terrifying Phenomenon I Discovered While Repairing an Analog Board
Compact Macs
Today, while repairing an analog board for a Macintosh Plus, I stumbled upon a phenomenon: when the 12V is overloaded, the 5V voltage...
Oct 29, 2025
A
ArjenCNX
wow, and for $35,- that's a steal! with HDMI i'd have to guide that cable through, maybe we can power the LCD from the USB-C power plug...
Oct 29, 2025
There’s an even smaller version of the same exact thing made for the IIc that came out AFTER I acquired my setup...
Oct 29, 2025
A
ArjenCNX
the fit right now is quite tight actually, there is no extra space inside to place a larger display, it would require a re-design of the...
Oct 29, 2025
TheElk
No more issues ( histogram disappears, black lines in the stored frames ) with reels having over 16384 frames ( reels bigger than 5 inch...
Oct 29, 2025
@ArjenCNX All excellent info, especially the EBAY link. Thank you! One question... Would it be possible to shrink your bezel to fit...
Oct 29, 2025
A
ArjenCNX
Turns out Eyoyo has a website for the US market with links and all (I finally remembered) https://www.eyoyousa.com/
Oct 29, 2025
A
ArjenCNX
Valid points, 1: I found it on Ebay https://www.ebay.com/itm/267198515931, I'm based out of northern Thailand, on the Asian...
Oct 29, 2025
