S
SportBikePilot
A Terrifying Phenomenon I Discovered While Repairing an Analog Board
It would be great if you could document this here for the rest of us that might need it someday. At least you've found this issue.
Oct 29, 2025
N
nottomhanks
Flippy-Floppy Video REVIEW
Hey, just reanimating this thread, can we use the Flippy Floppy with the Apple III Plus? Just plug the internal drive into A and Floppy...
Oct 29, 2025
D
dougg3
When I was investigating an older version of the Flasher app, I saw that there was an option bit that would cause the unlock/erase/etc...
Oct 29, 2025
Did Apple reverse the order of the data bits for 8 of the 16 Am28F020 chips? i.e. D0-D7 -> D7 D0?
Oct 29, 2025
1. I wasn’t able to find it on Amazon initially using the model number. However, I did find this, and looking at the pictures, it...
Oct 29, 2025
TheElk
It seems, that I'm recognising something mysterious. I'm scanning one film after an other. After some films I switch off the scanner...
Oct 29, 2025
Wow. This is the first I've heard of that problem. The 128K through the Plus use essentially the same Analog Board, so it would...
Oct 29, 2025
I also have Plamen's IIc to VGA adapter, and since my Eyoyo has VGA as well as HDMI, I could compare it with the A2DVI interface. The...
Oct 29, 2025
