I’ve ordered your existing 3d parts from JLCPCB in their white resin. I’m planning on using the 8” screen I found on Amazon that...
Oct 30, 2025
I
iigs123
If I were you I'd check all the traces first before trying to remove any components. I suppose bad VRAM could cause it. I don't know if...
Oct 30, 2025
Awesome. I’ll take a look at that and see if maybe there is an issue with any of the traces. Would a bad on board memory chip cause...
Oct 30, 2025
The 12mm is a really good fit, with some overscan. A 12mm macro like this one, should have been the original choice for this hardware...
Oct 30, 2025
It would be wrong for changes to be made only for me, so I agree there needs to be feedback from other Apple IIc owners. Maybe...
Oct 30, 2025
A
ArjenCNX
I'm willing to make the needed modifications to the existing design, if you can reach some consensus on what would be best, and provide...
Oct 30, 2025
S
sheider
That's definitely good news about the 12mm lens being a match, but bad news about the 16mm lens. @0dan0 Do you still have any hope of...
Oct 30, 2025
eyeidea
Mine will be here in a few days!
Oct 30, 2025
My lenses order form RMA ELECTRONICS arrived. The AZURE-1228MAC is confirmed to be same lens as the one from Scorpion. The secondary...
Oct 30, 2025
I
iigs123
You might have some bad traces from the VRAM to the CLUT. I googled a 650 motherboard pic and I believe it is the "Antelope" chip...
Oct 30, 2025
Macintosh Quadra & Centris
So, I’ve been working on a few of the last of the machines I picked up late last year. One of them was a battery bombed 650 that had a...
Oct 30, 2025
jeffburg
iMac G4 constantly crashing/kernel panics
Ok sounds good. Then my default guess would be RAM. But in OSX you should check the panic logs and see if you notice something...
Oct 30, 2025
