The 650 definitely wouldn’t boot with two of the F245s removed! I’ll try to run through the traces tonight. Thanks!
Oct 30, 2025
I’ve ordered your existing 3d parts from JLCPCB in their white resin. I’m planning on using the 8” screen I found on Amazon that...
Oct 30, 2025
I
iigs123
If I were you I'd check all the traces first before trying to remove any components. I suppose bad VRAM could cause it. I don't know if...
Oct 30, 2025
Awesome. I’ll take a look at that and see if maybe there is an issue with any of the traces. Would a bad on board memory chip cause...
Oct 30, 2025
The 12mm is a really good fit, with some overscan. A 12mm macro like this one, should have been the original choice for this hardware...
Oct 30, 2025
It would be wrong for changes to be made only for me, so I agree there needs to be feedback from other Apple IIc owners. Maybe...
Oct 30, 2025
A
ArjenCNX
I'm willing to make the needed modifications to the existing design, if you can reach some consensus on what would be best, and provide...
Oct 30, 2025
S
sheider
That's definitely good news about the 12mm lens being a match, but bad news about the 16mm lens. @0dan0 Do you still have any hope of...
Oct 30, 2025
eyeidea
Mine will be here in a few days!
Oct 30, 2025
My lenses order form RMA ELECTRONICS arrived. The AZURE-1228MAC is confirmed to be same lens as the one from Scorpion. The secondary...
Oct 30, 2025
I
iigs123
You might have some bad traces from the VRAM to the CLUT. I googled a 650 motherboard pic and I believe it is the "Antelope" chip...
Oct 30, 2025
