I didn’t think about doing screenshot. I assumed it was something on the output side. Since the lines show up in the screenshot, this...
Oct 31, 2025
AlexMac
Quadra 700 feet project
Just printed those: https://web.archive.org/web/20200507223308/www.synack.net/~bbraun/mac3d/ They look good (I know, I know, wrong...
Oct 31, 2025
I
iigs123
I'd check all of the traces between the onboard VRAM, VRAM SIMMs and the CLUT.
Oct 31, 2025
I
iigs123
Q610 VRAM issue
It does have B&W mode, but fortunately (or unfortunately) the video is perfect until I switch to Thousands of colors. The size of the...
Oct 31, 2025
Hmmm.... The Mac version doesn't want to let me import STP... If you cannot create an STL file (which all modern Macs support on the...
Oct 31, 2025
Right. There's some code that chooses between different Erase and Program methods. My emulation return 01/2A as manufacturer / device...
Oct 31, 2025
A
ArjenCNX
it might be that STL files are natively supported and STP files are not, i generally use Linux, so i would not know :cool:
Oct 31, 2025
A
ArjenCNX
actually, this was not supposed to get posted yet, i will mend it today once i found the correct files :-)
Oct 31, 2025
A
ArjenCNX
you could use prusa slicer to watch the files
Oct 31, 2025
PDf[31:0] at U8 in the Quadra 800 schematics...
Oct 31, 2025
I would have to look at a schematic to know the actual names of the signals/traces. Can you take a screenshot? If the problem is not...
Oct 31, 2025
I can open and rotate STL files merely by selecting the file on my Mac and pressing the Spacebar for QuickLook, but how are STP files...
Oct 31, 2025
A
ArjenCNX
Ibook G3 battery pack Oh, found another one, this one is tricky to print, and im not 100% happy with it but it is the Ibook G3 battery...
Oct 31, 2025
What's the best Video solution for a Vintage Apple IIe in 2025?
Color fringing seems excessive. A white horizontal line should ideally not have color fringing at either end (unless a line or bit...
Oct 31, 2025
