Peter-Erik
SE/30 -> Default state of NEC VRAM
Thanks i do that first, keep you posted, need to order those parts, delevery at least a week i guess thanks for your time David
Friday at 10:14 PM
The first line begins at offset 0 of the frame buffer. The most significant bit (bit 7) of the fist byte is the top left pixel. 32 bits...
Friday at 10:10 PM
Looking at the image in Basilisk II, the black line repeats at pixel 2 (with the far left pixel starting at 0), then repeats every 32...
Friday at 9:55 PM
Good point. I forgot you had brass inserts. I may need to do a bit of drilling and glueing. I'll let you know how I get it put...
Friday at 9:46 PM
I
iigs123
Q610 VRAM issue
The screen shot I posted was captured on the Q610, then displayed on my macbook. I couldn't save as JPG or something else, so I took a...
Friday at 9:26 PM
Q610 VRAM issue
You're not viewing that screenshot on the same computer that took the screen shot? Can you post a copy here (convert to png using...
Friday at 9:12 PM
I think so. Looks like line 29 of one of the 32-bit buses. Maybe post the screenshot here so we can count the pixels. If the problem...
Friday at 9:06 PM
If it were my board, I would remove both of those. Then, clean the area well to spot any broken traces. Then replace them with new...
Friday at 7:50 PM
Peter-Erik
So what do you think about the UE8 and UF8? Corrosion look severe if you compare it with rest of the board
Friday at 7:23 PM
Yes! Absolutely. What worries me about your photo is that I'm not seeing any on-screen images from ROM. No cursor, disk, or desktop...
Friday at 6:58 PM
I
iigs123
It seems like it would be on the D[0]-D[31] side. There are other video memory related signals that come out of the djMEMC chip you...
Friday at 5:56 PM
Given that the corruption shows up in my screenshot, would the data lines be D[31:0], or are you talking about the PD[31:0]?
Friday at 5:49 PM
