In your screenshot, the first 4 bytes of the framebuffer is 07FFFFFF hex. That is 5 zero bits (black pixels) followed by 27 one bits...
Oct 31, 2025
Peter-Erik
SE/30 -> Default state of NEC VRAM
Thanks i do that first, keep you posted, need to order those parts, delevery at least a week i guess thanks for your time David
Oct 31, 2025
The first line begins at offset 0 of the frame buffer. The most significant bit (bit 7) of the fist byte is the top left pixel. 32 bits...
Oct 31, 2025
Looking at the image in Basilisk II, the black line repeats at pixel 2 (with the far left pixel starting at 0), then repeats every 32...
Oct 31, 2025
Good point. I forgot you had brass inserts. I may need to do a bit of drilling and glueing. I'll let you know how I get it put...
Oct 31, 2025
I
iigs123
Q610 VRAM issue
The screen shot I posted was captured on the Q610, then displayed on my macbook. I couldn't save as JPG or something else, so I took a...
Oct 31, 2025
Q610 VRAM issue
You're not viewing that screenshot on the same computer that took the screen shot? Can you post a copy here (convert to png using...
Oct 31, 2025
I think so. Looks like line 29 of one of the 32-bit buses. Maybe post the screenshot here so we can count the pixels. If the problem...
Oct 31, 2025
If it were my board, I would remove both of those. Then, clean the area well to spot any broken traces. Then replace them with new...
Oct 31, 2025
Peter-Erik
So what do you think about the UE8 and UF8? Corrosion look severe if you compare it with rest of the board
Oct 31, 2025
Yes! Absolutely. What worries me about your photo is that I'm not seeing any on-screen images from ROM. No cursor, disk, or desktop...
Oct 31, 2025
I
iigs123
It seems like it would be on the D[0]-D[31] side. There are other video memory related signals that come out of the djMEMC chip you...
Oct 31, 2025
