A
ArjenCNX
if you need any more in-depth information, just let me know ill share what i can to support your build!
Nov 3, 2025
Has that SCSI driver VERSION issue been proven? I only realized today that my BlueSCSI v2 is using a Disk Jockey created image, and...
Nov 3, 2025
There are newer Flasher utilities that support later PowerPC Macs besides PDM and TNT but that doesn't matter for this ANS project...
Nov 3, 2025
Thank you for that confirmation. And just to add one detail... The clear MacEffects speaker looks great in the clear case, but...
Nov 3, 2025
Byte Knight
DOS on Mac
It looks like there's a patch for the OT issue here. How exactly did you get networking to work in Windows 95? The DOS on Power Mac...
Nov 3, 2025
I actually watched this video and it seems like the resin prints may be ok with just screwing directly into the part. But that may not...
Nov 3, 2025
OK, I was able to pull the 33MHz full 040 from the bombed Quadra 800 I had and swapped out the resistor, and the clock from the Q800...
Nov 3, 2025
A
ArjenCNX
the top corner holes have an ID of 4.5mm my inserts have an OD of 5mm, but you can grind them down to 4.5 without too much issue and...
Nov 3, 2025
B
Blinkz
TPU and Flexible PLA feel relatively similar when they are as thin as this since its basically solid infill at 1.5mm thickness. Holding...
Nov 3, 2025
