Byte Knight
DOS on Mac
After installing the "Existing ODI Driver" in Windows 95, I don't have a C:\NWCLIENT folder. I've got a C:\Novell folder with Client32...
Nov 4, 2025
So you didn't buy from the EBAY seller and instead bought it from an "Asian web shop"? The reason I ask is because that EBAY seller...
Nov 4, 2025
Z
zinco
Apple IIGS repair - boots to error code
From what my repairman tells me, this error code is as far as the computer goes when booting. Part of the reason he suspects the SCC...
Nov 4, 2025
Actually, error 06xxxxxx can be one of two things: it can be indeed the serial I/O, but it can also be the clock. You would not be able...
Nov 4, 2025
What I've received as of late...
Thanks for sharing that photo. I always loved the easy to see orange color scheme of the 48SX.
Nov 4, 2025
T
thjakob
Hello eyeidea I'm very curious to see how you determine the correct “thickness” of the sensor base. If I understand correctly, the aim...
Nov 4, 2025
Volvo242GT
@JDW, here are the two calculators together. More stuff conquested... Two Farallon EtherMac 10baseT AAUI dongles. One will be used...
Nov 4, 2025
T
thjakob
With the now modified lens, I have started to “unwind” my film rolls :) I have the odanO 7.1.1 firmware on a C-model and have noticed...
Nov 4, 2025
eyeidea
Would really like to add any and all LENS info, parts lists, 3D print models, and links to this master guide. 😎
Nov 4, 2025
eyeidea
My lens and parts arrived. Next step is to 3D print the adapter.
Nov 4, 2025
