Macintosh Portable: "pop" noise every 10s from Speaker & Headphones
Today, I came across this very interesting post by @David Cook where he attached his patched edition of System 6.0.8L that works on many...
Nov 4, 2025
PSU for SE & SE/30 trips breaker on 240VAC?
Well, I'm not sure what the exact problem is, but thank you for joining us here on TinkerDifferent. I hope you enjoy the forum!
Nov 4, 2025
muse
I built a SixtyClone recently with mostly pulled original chips. Those are fun to build.
Nov 4, 2025
muse
I'm the one with this problem, thanks to JDW for relaying my question from YT. To further isolate the fault, I disconnected the power...
Nov 4, 2025
V
V.Yakob
DOS on Mac
Try to add it to STARTNET.BAT C:\Windows\LSL.EXE C:\Apple\MACODI.COM But please note that NET.CFG should be located in the same place...
Nov 4, 2025
A
ArjenCNX
Hmmm... it was a long time ago i bought this, so forgive me for not remembering the exact vendor, i suspect i got it from lazada...
Nov 4, 2025
Byte Knight
DOS on Mac
After installing the "Existing ODI Driver" in Windows 95, I don't have a C:\NWCLIENT folder. I've got a C:\Novell folder with Client32...
Nov 4, 2025
So you didn't buy from the EBAY seller and instead bought it from an "Asian web shop"? The reason I ask is because that EBAY seller...
Nov 4, 2025
Z
zinco
Apple IIGS repair - boots to error code
From what my repairman tells me, this error code is as far as the computer goes when booting. Part of the reason he suspects the SCC...
Nov 4, 2025
Actually, error 06xxxxxx can be one of two things: it can be indeed the serial I/O, but it can also be the clock. You would not be able...
Nov 4, 2025
