thecloud
Assembly
Patching 68K software - SimpleText
Instead of declaring a variable in the middle of your code and then having to branch over it to the RTS, can't you just put the RTS...
Nov 5, 2025
I thought BlueSCSI speed gains from FWB HDTK only came on faster 030 or 040 Macs, especially when running OS 8.x or higher. And for...
Nov 5, 2025
Rob did a fantastic job of the clones. It's because of his work with the A500++ project that led me into learning sprint layout, and...
Nov 4, 2025
N
NJRoadfan
DOS on Mac
"Obtain IP Address Automatically" is DHCP and should work. One thing to try is changing the TCP/IP connection in Open Transport to...
Nov 4, 2025
P
Paolo B
Interesting point, I need to take my Portable out of the closet and check the driver (likely: FWB HDT, though)…
Nov 4, 2025
T
thjakob
Hello TheElk, I can't reproduce your findings. My 32GB card isn't recognised (as soon as I try to start recording, this yellow St...
Nov 4, 2025
Nixontheknight
Takky Upgrade
Which logic board are you using? There are certain ones that require the addition of a 3.3V regulator and additional power supply per...
Nov 4, 2025
It’s also important to consider that the 8 inch Eyoyo model (TFT) appears to be 800 x 600 resolution, whereas the knockoff 10 inch...
Nov 4, 2025
