N
NJRoadfan
DOS on Mac
Technically yes if you can find an old copy of PCMacLan that works on Windows 95. COPSTalk was also available as well. Also, if running...
Nov 5, 2025
P
piom
Apple IIc TDK internal power converter schematics / info
The difference I see is SHARP IR9494 in mine vs NEC uPC494C in yours - if it has been replaced then compare pinout of yours in datasheet...
Nov 5, 2025
TheElk
What Blocksize did you use ? See my answer on post ( #859 ). May be try to put a small file on the card when attached to your PC.
Nov 5, 2025
TheElk
I have to correct my expression. I formatted the ard with 8 k, showing the cross with and without a file, 16 k showing the cross with...
Nov 5, 2025
A
ArjenCNX
Colour classic learnings of the day
Compact Macs
Hi everyone, I'm making this post just to memorize and help those with a similar issue. While upgrading a colour classic with a mystic...
Nov 5, 2025
tom_B
System source swap meet this weekend(nov 8th) - Hunt Valley, MD
Events & Meet-ups
https://vcfed.org/system-source-swap-meet/ I'm likely going
Nov 5, 2025
Byte Knight
DOS on Mac
Success (finally)! I had to manually specify the IP address, subnet mask, and DNS in Windows 95. I was even able to find a much...
Nov 5, 2025
RetroTechTom
updated their
status
Bought a Radeon 7000 PCI graphics card for my Macintosh Server G3 Blue and White I will have to get some replacement case parts and...
Nov 5, 2025
Volvo242GT
What I've received as of late...
If you change your mind... ;-)
Nov 5, 2025
