Jockelill
Macintosh IIsi Oscillator-Replacement Overclock Successes and Fails
It works, I've done several, however you are now running also the PDS slot at 25MHz, and not all expansion cards are happy with that...
Nov 5, 2025
mbone
"Brand New" USB Translucent Zip Drive Error
Hi, Has anyone managed to fix this issue? It appears to be a common problem with the USB type zip drive. I have 2x that have same issue...
Nov 5, 2025
A
azure78
REVIEW of Mockingboard 4c for Apple IIc
Thanks JDW for the great review. I have one question for those that have one and use a A2CDVI v2.5 or similar with audio out ... does...
Nov 5, 2025
N
NJRoadfan
DOS on Mac
Technically yes if you can find an old copy of PCMacLan that works on Windows 95. COPSTalk was also available as well. Also, if running...
Nov 5, 2025
P
piom
Apple IIc TDK internal power converter schematics / info
The difference I see is SHARP IR9494 in mine vs NEC uPC494C in yours - if it has been replaced then compare pinout of yours in datasheet...
Nov 5, 2025
TheElk
What Blocksize did you use ? See my answer on post ( #859 ). May be try to put a small file on the card when attached to your PC.
Nov 5, 2025
