I just picked up a Creality CR10 v2 from FB marketplace this morning... so running a first test print it may not be suitable until...
Nov 9, 2025
Some older players are not acknowledging the full range metadata, that is not sharpness, rather an increase in contrast (also a clipped...
Nov 8, 2025
S
Scout
6100 Schematic?
Cleaned up my recap job and found one very close to traces. Picture attached. I cleaned up and coated the traces with lacquer. Now...
Nov 8, 2025
CamInTosh
MacSE analog board issue – squished video, flyback overheating
Wanted to update earlier, just things kept coming up... It's all fixed. I replaced BU406 (which DID have that purplish burn mark on...
Nov 8, 2025
3lectr1c
68kmla MIA
I don't doubt that Cory has been too busy to spend much time working on new features/improvements to the site, but if he has time to...
Nov 8, 2025
T
ThePhage
Check that you have the film fed under the 4 black tabs in the scan path. Depending on how/where the film is coming out, you may need to...
Nov 8, 2025
V
VoodooKi
Is there any trick to keeping the film in the tracks as it being process?
Nov 8, 2025
