jmacz
Green Tint on VGA CRT Monitor Connected to Macintosh IIx
There is a control panel named Gamma which might help. It’s not Apple’s, it’s aftermarket. I think it’s on Macintosh Garden. It does...
Nov 10, 2025
jmacz
Macintosh PortraitDisplay Recap and Geometry Adjustments
The Apple 8*24 card will also drive it. I believe the on board video on a IIci worked for me as well.
Nov 10, 2025
A
ArjenCNX
Color Classic VGA Woes
Thank you sir! i also have a big box of capacitors here bought as a pack per kilo, usually works, but contains nothing over 450V, ill...
Nov 10, 2025
That's why I had to create an inventory management system... I kept forgetting what I had and what I had done to each thing. I haven't...
Nov 10, 2025
Retrobrite for eMac
Completely off topic (sorry op) but wouldn’t it be neat to strip all the white off to clear so you get to see all of the awesome...
Nov 10, 2025
Brittle Plastic Writeup
Thanks so much for sharing.
Nov 10, 2025
Well, that's a ceramic. Using a polypropylene film cap will result in better stability over the operating temperature range. No DC...
Nov 10, 2025
I discuss CL26 in my video below starting at 49:00... So while it's actually 1nF~3.9nF, not 4.7nF, you can use 1000V or higher film...
Nov 10, 2025
A
ArjenCNX
i found this part at LCSC https://www.lcsc.com/product-detail/C249170.html i think this will fit
Nov 10, 2025
Mk.558
Modern MacBinary Tool for MacOS 26
I use a "swap" disk image. A .dmg image file that works like a transfer disk. Open it on macOS, drop what you got in there, unmount it...
Nov 10, 2025
