Macintosh Server G3
Im guessing. Basically between the Workgroup Server line and the Xserve that would come out in the G4 era.
Nov 12, 2025
C2 Capacitor Replacement on Mac 512k Analog Board Smoking
You determined smoke was coming from C2 and not from any other component. Therefore, C2, and everything directly connected to C2 must...
Nov 12, 2025
P
papapoipoi
[2GS] Using SCSI drives
Did some extra tests, but still not more that two disks visible... I'm quite confused. Documentation says that It should be plugged in...
Nov 11, 2025
D
DarylVogel
Can we reasonably isolate the problem to ONLY items that are connected to C2? As opposed to other items not connected to C2?
Nov 11, 2025
D
DarylVogel
Thank you everyone for the replies and suggestions. Is there a way, perhaps using an ammeter, to *specifically* target where the issue...
Nov 11, 2025
A
AlpineRaven
SD to IDE drive replacement for PDQ PowerBook G3
I recently did benchmark and tested to see which was better for my PowerBook G3 - I am doing mix-n-match and build good one. attached...
Nov 11, 2025
XodiumLabs
Flashing the Silicon Image Sil3112 to work in Macs (2025 Edition)
Good call on this and I'll be giving it a try tonight. Was actually starting to look that direction because the card in my MDD seems to...
Nov 11, 2025
mmu_man
Snow EMU - Emulator for 680x0-based Macintosh computers
So powerful it even emulates an Atari \o/ … Kidding, that's my EmuTOS port to Apple just starting up. Not fond of having to download...
Nov 11, 2025
IC puller for socketed chips
Did it require something special, or just a standard PLCC puller?
Nov 11, 2025
Macintosh Server G3
I'm assuming this is the last gasp of the Workgroup Server line.
Nov 11, 2025
