chuma
Emate 300 without battery pack
Could be the screen contrast - slider position or the slider component itself - though if the volume's up then the eMate should emit the...
Nov 12, 2025
Mk.558
Macintosh Server G3
ya. The one I fooled around with would refuse to boot OS X 10.0.3. Boot loops, broken folder icon and other weird things. Somehow I...
Nov 12, 2025
New tool to remove capacitor and rust corrosion - the dental scaler!
Macintosh II
I purchased a IIfx that appeared to be in great shape. No battery leaks. Light capacitor leakage (no damaged traces). I recapped it and...
Nov 12, 2025
N
NJRoadfan
Macintosh Server G3
Both cards were BTO options on the beige G3, so no surprises there. The server configurations generally came with AppleShare IP...
Nov 12, 2025
Macintosh Server G3
Im guessing. Basically between the Workgroup Server line and the Xserve that would come out in the G4 era.
Nov 12, 2025
C2 Capacitor Replacement on Mac 512k Analog Board Smoking
You determined smoke was coming from C2 and not from any other component. Therefore, C2, and everything directly connected to C2 must...
Nov 12, 2025
P
papapoipoi
[2GS] Using SCSI drives
Did some extra tests, but still not more that two disks visible... I'm quite confused. Documentation says that It should be plugged in...
Nov 11, 2025
D
DarylVogel
Can we reasonably isolate the problem to ONLY items that are connected to C2? As opposed to other items not connected to C2?
Nov 11, 2025
D
DarylVogel
Thank you everyone for the replies and suggestions. Is there a way, perhaps using an ammeter, to *specifically* target where the issue...
Nov 11, 2025
