thecloud
Thanks to @eric , sit now has AppleDouble file support and should be able to compile on non-macOS systems.
Nov 19, 2025
Desktop G3 Zip/Jaz bezel
Wow, that looks like an aftermarket Zip drive to me. The bezel doesn’t look like it fits quite right along with the wonky drive in there...
Nov 19, 2025
B
blturner
PCI-based Power Macintosh
Does anyone know anything about the bezel seen in this photo? It's from an auction on shopgoodwill.com and I've never come across a...
Nov 19, 2025
XodiumLabs
Flashing the Silicon Image Sil3112 to work in Macs (2025 Edition)
Okay! Couple things: 1. I got my hands on a Rabbit Hole RetroSATA. Not sure that I'd recommend anyone buy these cards just yet (not...
Nov 19, 2025
muse
It could also be a result of the 4 SMD capacitors around the analog video section on the logic board which havent been replaced yet...
Nov 19, 2025
muse
More recent gamers might be able to comment. But I've never known it to be common on any joysticks I've ever used. I also prefer the...
Nov 19, 2025
Correct in that my joystick kit does NOT include the "rubber sleeve" that slides onto the shaft. I found a YouTube video with a greed...
Nov 19, 2025
muse
Theres a rubber sleeve which comes with this product ( I'm not seeing it in your package though ) that fits over the shaft to prevent...
Nov 19, 2025
A
ArjenCNX
I'd second that, noise is likely from the analog board, and likely related to capacitors, im not sure if you have swapped out all...
Nov 19, 2025
Welcome to TinkerDifferent! With the exception of the floppy drive (which doesn't matter in this case), you clearly have a fully...
Nov 19, 2025
