Desktop G3 Zip/Jaz bezel
Probably the distance from the top of the drive to the top of the case (if even possible), or the distance from the bottom case to the...
Nov 19, 2025
MeTheMac
Cracked Hinge on Mac Portable
Honestly, at the point I'm drilling through plastic on such a hard to find machine I'd rather just sacrifice daily closing-and-opening...
Nov 19, 2025
Sure, although I'm not exactly sure what to measure... perhaps the rectangular slot dimensions and its distance from the top and sides?
Nov 19, 2025
P
Paolo B
First off, I would disassemble the Portable, in order to have a more freedom to operate. The Portable was famously designed to be...
Nov 19, 2025
MeTheMac
I had this issue as well. I could find zero info on it at all and its like my precious machine lol. I decided the best option for me was...
Nov 19, 2025
S
Scout
Macintosh Quadra & Centris
The battery took out the switches on the logic board. Are they common and avaible to purchase? the buttons in the case are fine but it...
Nov 19, 2025
Help, “Pretty please”? 😢
Nov 19, 2025
MeTheMac
VCF Swap Meet Sat Oct 18 2025 Wall NJ
Wish I could have come!`
Nov 19, 2025
MeTheMac
Hi all! Haven't been on in a while. Last time I was messing with an Apple IIc. I'm definitely going to read up tonight!
Nov 19, 2025
MeTheMac
Today’s pickup - “portable” IIgs setup - help needed
Woah. Haven't been on the forums in 3 months and find my favorite computer in a portable form factor! Yes, please. I'll get to reading...
Nov 19, 2025
Voltages are lower with the Meanwell module type replacement PSUs. When I reviewed the Baby Face PSU, I compared it to the Stock SONY...
Nov 19, 2025
Both at ROM 01 machines, so no real advantage there. I need to read more up on the accelerator - I suspect it will benefit running...
Nov 19, 2025
The hex profile for the hote worked great, except for the fact that the slot doesn't align with the elbow. If you could rotate it a bit...
Nov 19, 2025
