Desktop G3 Zip/Jaz bezel
The opening "hole" is 102mm wide by 25.5mm high. the width measured at each of the four corners of the hole is different. Top Left...
Nov 20, 2025
N
NJRoadfan
I'll get around to adding full native macOS FinderInfo metadata support.
Nov 20, 2025
N
NJRoadfan
Today’s pickup - “portable” IIgs setup - help needed
The ZipGSX requires a utility to turn the accelerator on or off. Unlike the TranswarpGS which has that fancy built-in CDA. The cables...
Nov 20, 2025
Ok, so this bezel lets the whole face of the drive be seen, vs the 9100/9500 type bezel that only lets the media slot be shown...
Nov 20, 2025
Cracked Hinge on Mac Portable
OK, well... While I ponder the toxic and cancer-causing risks of Weld-On 16, I'd like to go back to my Question #1 of my opening post...
Nov 20, 2025
Dave928
Baby Face in mine, works well. only thing not to like is all the text is upside-down. will try the TT Design when (if) they become...
Nov 20, 2025
@Stephen I think already modelled a bezel like this for a magneto optical drive, for these models...?
Nov 20, 2025
Got the calipers out... The top measure is 4.5mm. The bottom one is a bit trickier, with one side of the caliper square and flat in the...
Nov 20, 2025
I wonder if @Stephen may be able to assist, recently in the discord server he showed some 3d printed metal hinges... May be possible to...
Nov 20, 2025
MeTheMac
Side note: anyone who wants to make a mold, count me in. I'm willing to pay the price for such a thing, as I'm sure many would
Nov 20, 2025
I took your parts and modified them a bit for resin printing. I twisted the hex pattern in the knob to allow the hex key to fit and...
Nov 20, 2025
