Rear Admiral
Well! My hotly-anticipated vintage Apple IIe arrived, and the case is shattered. FML.
One of the things I enjoy about this hobby is the opportunity to learn about the history of these machines. The seller, as it turns out...
Nov 20, 2025
robin-fo
You can still buy the exact same from Mouser. You‘ll have to reuse the plastic brackets though..
Nov 20, 2025
thecloud
Can you explain what that would mean? The contents of the com.apple.FinderInfo extended attribute seem to be the same 32 bytes found in...
Nov 20, 2025
Pepper
PowerMac G5 Quad PSU Pinout
PowerMac G5 & iMac G5
I had a hard time finding the pin-out for the G5 Quad PSU, so I document it here (: Apple 614-0384 - 1000W Power Supply for Powermac...
Nov 20, 2025
P
Paolo B
Cracked Hinge on Mac Portable
I did a similar intervention on a HP712 top lid. It’s not for the faint of heart, but doable. With the help of a bench drill, which can...
Nov 20, 2025
jmacz
I don’t have a Portable. Too scared of tunnel vision to ever look into acquiring one. But if I were in that position, I would machine...
Nov 20, 2025
jmacz
The 12x12 switch included in this assortment on Amazon worked for me: https://www.amazon.com/dp/B0BFWK5N8V It’s basically the exact...
Nov 20, 2025
MeTheMac
Today’s pickup - “portable” IIgs setup - help needed
Very. Be incredibly careful. You have been warned. Definitely no experience with that sob
Nov 20, 2025
Desktop G3 Zip/Jaz bezel
The opening "hole" is 102mm wide by 25.5mm high. the width measured at each of the four corners of the hole is different. Top Left...
Nov 20, 2025
N
NJRoadfan
I'll get around to adding full native macOS FinderInfo metadata support.
Nov 20, 2025
N
NJRoadfan
The ZipGSX requires a utility to turn the accelerator on or off. Unlike the TranswarpGS which has that fancy built-in CDA. The cables...
Nov 20, 2025
Ok, so this bezel lets the whole face of the drive be seen, vs the 9100/9500 type bezel that only lets the media slot be shown...
Nov 20, 2025
