N
NJRoadfan
Not every file has a resource fork (this is certainly the case for Apple II files stored on Macintosh volumes) and the resource fork...
Nov 20, 2025
muse
Don't know if I'd ever want to use one of those replacements. They seem quite noisy. 80mVp-p for the 60-5 module 120mVp-p for the...
Nov 20, 2025
annawat4
Colour classic learnings of the day
As far as I know, on updated Mystic Color Classics, the bus error can be fixed. If you correctly configure the analog board ID pins.
Nov 20, 2025
FinderInfo and ResourceFork are two separate file system objects so they can have different data. xattr -lpx com.apple.FinderInfo...
Nov 20, 2025
Cracked Hinge on Mac Portable
Do 0.8 mm drill bits like bending forces or are they brittle in the non-vertical direction? How wide are the ribs? How long are the...
Nov 20, 2025
Rear Admiral
Well! My hotly-anticipated vintage Apple IIe arrived, and the case is shattered. FML.
One of the things I enjoy about this hobby is the opportunity to learn about the history of these machines. The seller, as it turns out...
Nov 20, 2025
robin-fo
You can still buy the exact same from Mouser. You‘ll have to reuse the plastic brackets though..
Nov 20, 2025
thecloud
Can you explain what that would mean? The contents of the com.apple.FinderInfo extended attribute seem to be the same 32 bytes found in...
Nov 20, 2025
Pepper
PowerMac G5 Quad PSU Pinout
PowerMac G5 & iMac G5
I had a hard time finding the pin-out for the G5 Quad PSU, so I document it here (: Apple 614-0384 - 1000W Power Supply for Powermac...
Nov 20, 2025
