N
NJRoadfan
The "Finder Flags" are the 4 bytes after the 8 bytes of File Type/Creator. Its stores things like the color/label, "has custom icon"...
Nov 21, 2025
O
Oelmuvun
Cracked Hinge on Mac Portable
You guys keep talking about drilling holes with impossibly thin and long drills, but may I ask why we aren't stitching the plastic by...
Nov 21, 2025
The question at this stage focuses on what cement I should buy. Because even if I drill or add sewing needles, etc., the plastics still...
Nov 21, 2025
The file in my example has a resource fork without the type/creator that is in the FinderInfo. I think a correct implementation would...
Nov 21, 2025
Using "bolts/machine-screws" is not practical based on my observations of the machine, and you can kind of see that in the photo I...
Nov 21, 2025
@RolandJuno Thank you so much for answering my Question #1 !!! That's the GOLD MEDAL ANSWER! 🏅 More specifically, from the part of the...
Nov 21, 2025
It would be preferable to be able to have tension go all the way from the top of the rib to the other side so that new cracks can't...
Nov 21, 2025
thecloud
Just finished reimplementing compression. Since it's not guaranteed that a system will have the compress command available (and StuffIt...
Nov 21, 2025
warmech
Mac OS 7.6 Apple-Internal Gold Master
Software & Operating Systems
So, during VCFSW back in June, I eventually stepped away from my table to have a look around and came across something that I'd never...
Nov 20, 2025
