thecloud
LZW compression support is working and has now been merged to the main branch: https://github.com/thecloudexpanse/sit.
Nov 21, 2025
W
Wayne S
Well! My hotly-anticipated vintage Apple IIe arrived, and the case is shattered. FML.
There were 4 different cases but in the case of the bottom mount keyboard, the mounting is removeable. The bottom plate will then fasten...
Nov 21, 2025
MeTheMac
Cracked Hinge on Mac Portable
Does this help much with the smoothness of the hinge? Or is it not test-able yet due to the crack in the assembly? I'm considering doing...
Nov 21, 2025
ChatGPT contends that for use on polycarbonate, the original 24-hour cure JB Weld is better than the clay putty stick. 🤷♂️...
Nov 21, 2025
annawat4
Possible To Hide Partition From Desktop In Classic Mac OS 8.1 / 7.6.1 / 7.5.5?
Yes. There are a couple of ways you can hide a volume in classic Mac OS. For example, Wish I Were, TinkerTool, or by editing the Finder...
Nov 21, 2025
Your first post says JB Weld Epoxy does not bound well to polycarbonate (poor chemical bond). But what about using JB Weld Putty for...
Nov 21, 2025
O
Oelmuvun
I've never used the real tool, though I understand that different wire shapes are available. I've just been pushing bits of wire in with...
Nov 21, 2025
The app in my example was locked! After unlocking it, -d does work to remove (or hide) the FinderInfo. So both of these will remove the...
Nov 21, 2025
