thecloud
You can have this functionality without having StuffIt Deluxe 16 installed. Save the following into a file named "Create StuffIt...
Nov 22, 2025
MeTheMac
Cracked Hinge on Mac Portable
Oops quoted wrong . My bad!!! Thanks for the in-depth answer anyway, dont worry about it. Thx
Nov 22, 2025
You quoted the part of my earlier post where I was talking about JB Weld, so I assume you must be asking if JB Weld will stick onto the...
Nov 22, 2025
thecloud
LZW compression support is working and has now been merged to the main branch: https://github.com/thecloudexpanse/sit.
Nov 21, 2025
W
Wayne S
Well! My hotly-anticipated vintage Apple IIe arrived, and the case is shattered. FML.
There were 4 different cases but in the case of the bottom mount keyboard, the mounting is removeable. The bottom plate will then fasten...
Nov 21, 2025
MeTheMac
Does this help much with the smoothness of the hinge? Or is it not test-able yet due to the crack in the assembly? I'm considering doing...
Nov 21, 2025
ChatGPT contends that for use on polycarbonate, the original 24-hour cure JB Weld is better than the clay putty stick. 🤷♂️...
Nov 21, 2025
annawat4
Possible To Hide Partition From Desktop In Classic Mac OS 8.1 / 7.6.1 / 7.5.5?
Yes. There are a couple of ways you can hide a volume in classic Mac OS. For example, Wish I Were, TinkerTool, or by editing the Finder...
Nov 21, 2025
