muse
You'll need to drill a hole with a small drill bit and then expose the copper with a blade either side for the solder to adhere to...
Saturday at 6:13 AM
Cracked Hinge on Mac Portable
Okay, folks. After many hours of talking to ChatGPT and searching on my own, I've changed my mind about using screws or drilling holes...
Saturday at 5:37 AM
_nec6678
Green Tint on VGA CRT Monitor Connected to Macintosh IIx
Update! I've installed GammaCorrector 1.1.1 from the Macintosh Garden, and it has worked really well to get rid of the green tint! In...
Saturday at 3:06 AM
thecloud
You can have this functionality without having StuffIt Deluxe 16 installed. Save the following into a file named "Create StuffIt...
Saturday at 2:42 AM
MeTheMac
Oops quoted wrong . My bad!!! Thanks for the in-depth answer anyway, dont worry about it. Thx
Saturday at 2:34 AM
You quoted the part of my earlier post where I was talking about JB Weld, so I assume you must be asking if JB Weld will stick onto the...
Saturday at 1:35 AM
thecloud
LZW compression support is working and has now been merged to the main branch: https://github.com/thecloudexpanse/sit.
Nov 21, 2025
W
Wayne S
Well! My hotly-anticipated vintage Apple IIe arrived, and the case is shattered. FML.
There were 4 different cases but in the case of the bottom mount keyboard, the mounting is removeable. The bottom plate will then fasten...
Nov 21, 2025
MeTheMac
Does this help much with the smoothness of the hinge? Or is it not test-able yet due to the crack in the assembly? I'm considering doing...
Nov 21, 2025
ChatGPT contends that for use on polycarbonate, the original 24-hour cure JB Weld is better than the clay putty stick. 🤷♂️...
Nov 21, 2025
