Kay K.M.Mods
SPIISD V2 has been released
I forgot to share this awesome case that Bruce designed, and JDW is showcasing it with his YouTube Video...
Nov 22, 2025
Kay K.M.Mods
Hi James, Colinlm contacted me directly and I explained him that V2 is a closed source version, and he reassured me and agreed that I...
Nov 22, 2025
Cracked Hinge on Mac Portable
If you look closely, the tips are all sharp hooks... https://www.amazon.com/Plaque-Remover-Cleaning-Adjustable-Cleaner/dp/B0F1K99FCR...
Nov 22, 2025
I wonder if the mentioned dental scaler would work for removing this metallic covering?
Nov 22, 2025
Just had a new idea to supplement what my current plan. You can see on my Amazon order that I have a 2.0mm thick transparent...
Nov 22, 2025
LOL. I guess the lack of comments are basically telling me: "Go for it, James. We're waiting with bated breath to see if it works out...
Nov 22, 2025
muse
You'll need to drill a hole with a small drill bit and then expose the copper with a blade either side for the solder to adhere to...
Nov 22, 2025
Okay, folks. After many hours of talking to ChatGPT and searching on my own, I've changed my mind about using screws or drilling holes...
Nov 22, 2025
_nec6678
Green Tint on VGA CRT Monitor Connected to Macintosh IIx
Update! I've installed GammaCorrector 1.1.1 from the Macintosh Garden, and it has worked really well to get rid of the green tint! In...
Nov 22, 2025
thecloud
You can have this functionality without having StuffIt Deluxe 16 installed. Save the following into a file named "Create StuffIt...
Nov 22, 2025
MeTheMac
Oops quoted wrong . My bad!!! Thanks for the in-depth answer anyway, dont worry about it. Thx
Nov 22, 2025
You quoted the part of my earlier post where I was talking about JB Weld, so I assume you must be asking if JB Weld will stick onto the...
Nov 22, 2025
