cc333
CarbonLib on NewWorld Mac OS 7.6?
Software | Mac OS (PowerPC)
Now that NewWorld System 7 is a thing, has anyone successfully made CarbonLib work on it? I copied it over from 9.2.2, and it doesn't...
Nov 23, 2025
cc333
DVD Burning in OS 9
Yes, the feature is available in 9.1 and up. I don't know if it would work on 9.0.x, but I suppose it could if all the necessary bits...
Nov 23, 2025
O
Oelmuvun
Cracked Hinge on Mac Portable
Use the technology of the sanding block. You want to mate these two surfaces into each other, so use them together. Either use the...
Nov 23, 2025
thecloud
Thanks! I had noticed that my quick-and-dirty script was only handling one selection, and really needed to iterate over the list as you...
Nov 23, 2025
thecloud
1.5.1 in this case. :)
Nov 23, 2025
I'm only seeing this now in 5% or fewer captures, but maybe I'm lucky. As stated before, it also happens on stock firmware, but it would...
Nov 23, 2025
O
omega
I've written about it here before. Maybe it will help here too. #573
Nov 23, 2025
T
ThePhage
I can also report that several instances of my scans on a type C with 7.1.1 have frame jitter (frankly it happens more often than it...
Nov 23, 2025
