Cracked Hinge on Mac Portable
Better go with the full face shield as well?:oops:
Nov 24, 2025
Ah yes... Now ChatGPT says that even the DCM manufacturer-recommended PE is not enough... Naturally, all those EVOH and specialist...
Nov 24, 2025
Well everything is now only hold due to my compete lack of knowledge about chemical solvents and the SHEER STUPIDITY of ChatGPT. AI is...
Nov 23, 2025
cc333
CarbonLib on NewWorld Mac OS 7.6?
Software | Mac OS (PowerPC)
Now that NewWorld System 7 is a thing, has anyone successfully made CarbonLib work on it? I copied it over from 9.2.2, and it doesn't...
Nov 23, 2025
cc333
DVD Burning in OS 9
Yes, the feature is available in 9.1 and up. I don't know if it would work on 9.0.x, but I suppose it could if all the necessary bits...
Nov 23, 2025
O
Oelmuvun
Use the technology of the sanding block. You want to mate these two surfaces into each other, so use them together. Either use the...
Nov 23, 2025
thecloud
Thanks! I had noticed that my quick-and-dirty script was only handling one selection, and really needed to iterate over the list as you...
Nov 23, 2025
thecloud
1.5.1 in this case. :)
Nov 23, 2025
I'm only seeing this now in 5% or fewer captures, but maybe I'm lucky. As stated before, it also happens on stock firmware, but it would...
Nov 23, 2025
O
omega
I've written about it here before. Maybe it will help here too. #573
Nov 23, 2025
