A
ArjenCNX
how about screw inserts, what they use when the wire-tap is damaged? they look like springs. if you can insert that, it will cover much...
Nov 25, 2025
Yeah, I am hoping a liberal amount of superglue will hold as well as an insert. Alternatively, a longer screw with a nut that could be...
Nov 25, 2025
muse
He's swapped out the analog board as well, with the problem still present, which is wierd.
Nov 25, 2025
johntucker
@joevt , First I have seen the same notes that state that the ANS won’t boot from the internal fast and wide SCSI buss & that for MacOS...
Nov 25, 2025
I'm pretty sure (@johntucker can confirm) that the MacOS ROM does allow you to boot from the internal SCSI. But it could certainly boot...
Nov 25, 2025
BeniD82
Macintosh LC $20 rescue
My experience with the pizza box LC PSUs is that they need some load to regulate power properly. Without it you tend to get screwy...
Nov 25, 2025
BeniD82
Takky Upgrade
My Takky modded CC went through several iterations over the many years I've had it: Mystic, 630 DOS Compatible Board, and now a 6500/250...
Nov 25, 2025
The "Tantalum" Console5 kit for the SE/30 which the OP said he used includes polymer capacitors for C3, C4, C9, C10. I can confirm since...
Nov 25, 2025
muse
@JDW OP mentioned that he had geometry issues with the replacement CRT from the SE with the top left corner out of wack on the screen...
Nov 25, 2025
As mentioned in my earlier post, the opening post said he recapped everything, which I assumed meant literally that. So when I saw his...
Nov 25, 2025
