A
ArjenCNX
When i had video issues with this motherboard i always focus around UE8, that row of chips, it manages the video signal. soldering...
Nov 25, 2025
Macintosh LC $20 rescue
Good to know, thanks for that tip!
Nov 25, 2025
A
ArjenCNX
how about screw inserts, what they use when the wire-tap is damaged? they look like springs. if you can insert that, it will cover much...
Nov 25, 2025
Yeah, I am hoping a liberal amount of superglue will hold as well as an insert. Alternatively, a longer screw with a nut that could be...
Nov 25, 2025
muse
He's swapped out the analog board as well, with the problem still present, which is wierd.
Nov 25, 2025
johntucker
@joevt , First I have seen the same notes that state that the ANS won’t boot from the internal fast and wide SCSI buss & that for MacOS...
Nov 25, 2025
I'm pretty sure (@johntucker can confirm) that the MacOS ROM does allow you to boot from the internal SCSI. But it could certainly boot...
Nov 25, 2025
BeniD82
My experience with the pizza box LC PSUs is that they need some load to regulate power properly. Without it you tend to get screwy...
Nov 25, 2025
BeniD82
Takky Upgrade
My Takky modded CC went through several iterations over the many years I've had it: Mystic, 630 DOS Compatible Board, and now a 6500/250...
Nov 25, 2025
