PL212
Dark Castle is BACK!
You know, I really am happy that the codebase is being kept alive. I purchased the (2008?) App Store release, which I’m pretty sure is...
Tuesday at 3:38 AM
muse
I replaced all caps with low ESR, high quality Nichicon and Matsushita radials, they make them small enough nowadays and you can solder...
Tuesday at 3:37 AM
Are you taking about something like helical inserts? https://a.co/d/7kPyx3O If the resin material is brittle, would this helical coils...
Tuesday at 3:33 AM
Has anyone ever seen video issue exactly like this before? I'm certainly not an expert but I digital pixel wise the image looks correct...
Tuesday at 3:32 AM
A
ArjenCNX
When i had video issues with this motherboard i always focus around UE8, that row of chips, it manages the video signal. soldering...
Tuesday at 3:01 AM
Macintosh LC $20 rescue
Good to know, thanks for that tip!
Tuesday at 2:58 AM
A
ArjenCNX
how about screw inserts, what they use when the wire-tap is damaged? they look like springs. if you can insert that, it will cover much...
Tuesday at 2:49 AM
Yeah, I am hoping a liberal amount of superglue will hold as well as an insert. Alternatively, a longer screw with a nut that could be...
Tuesday at 2:43 AM
muse
He's swapped out the analog board as well, with the problem still present, which is wierd.
Tuesday at 2:13 AM
johntucker
@joevt , First I have seen the same notes that state that the ANS won’t boot from the internal fast and wide SCSI buss & that for MacOS...
Tuesday at 2:12 AM
I'm pretty sure (@johntucker can confirm) that the MacOS ROM does allow you to boot from the internal SCSI. But it could certainly boot...
Tuesday at 2:04 AM
