For the 47uf caps in the above mentioned Console5 kit for the SE/30 it contains 20V rated solid tantalums with the exception of c3, c4...
Nov 25, 2025
A
ArjenCNX
Maybe you are right, still, if we want to prevent stresses from building up, gluing is still best, this will need surface area to be...
Nov 25, 2025
A
ArjenCNX
I generally measure those buffer caps, and its exceedingly rare for them to fail, you can very likely re-use the old one. (that is my...
Nov 25, 2025
I don't concern myself with the failure mode of SOLID tantalum capacitors because I understand that most every manufacturer of those has...
Nov 25, 2025
PL212
Dark Castle is BACK!
You know, I really am happy that the codebase is being kept alive. I purchased the (2008?) App Store release, which I’m pretty sure is...
Nov 25, 2025
muse
I replaced all caps with low ESR, high quality Nichicon and Matsushita radials, they make them small enough nowadays and you can solder...
Nov 25, 2025
Are you taking about something like helical inserts? https://a.co/d/7kPyx3O If the resin material is brittle, would this helical coils...
Nov 25, 2025
Has anyone ever seen video issue exactly like this before? I'm certainly not an expert but I digital pixel wise the image looks correct...
Nov 25, 2025
A
ArjenCNX
When i had video issues with this motherboard i always focus around UE8, that row of chips, it manages the video signal. soldering...
Nov 25, 2025
Macintosh LC $20 rescue
Good to know, thanks for that tip!
Nov 25, 2025
A
ArjenCNX
how about screw inserts, what they use when the wire-tap is damaged? they look like springs. if you can insert that, it will cover much...
Nov 25, 2025
Yeah, I am hoping a liberal amount of superglue will hold as well as an insert. Alternatively, a longer screw with a nut that could be...
Nov 25, 2025
