N
NJRoadfan
The STB Horizon+ is a generic Cirrus Logic CL-GD5430 based card. That happens to be the same chipset hypervisors like QEMU have support for.
Nov 25, 2025
Cracked Hinge on Mac Portable
Okay, friends. I have test results for you. Here is a closeup of the bubbles again, this time shot from the bottom of the...
Nov 25, 2025
The GitHub points to a wiki and a Discord. We can answer all questions in the Discord. DingusPPC is a work in progress so lots of stuff...
Nov 25, 2025
V
Vogone
LibreSSL and OpenSSH on Mac OS X 10.5 Leopard?
Thank you both very much! Both ssheven and Dropbear seem to be good options if there are problems with LibreSSL and OpenSSH. Knowing...
Nov 25, 2025
For the 47uf caps in the above mentioned Console5 kit for the SE/30 it contains 20V rated solid tantalums with the exception of c3, c4...
Nov 25, 2025
A
ArjenCNX
Maybe you are right, still, if we want to prevent stresses from building up, gluing is still best, this will need surface area to be...
Nov 25, 2025
A
ArjenCNX
I generally measure those buffer caps, and its exceedingly rare for them to fail, you can very likely re-use the old one. (that is my...
Nov 25, 2025
