P
Paolo B
Cracked Hinge on Mac Portable
Agree: without proper reinforcement it will never work for regular use. 3D printing something out of metal seems to be an interesting...
Nov 26, 2025
Best monitor for vintage Macintosh
So if you don't use the adapter and directly connect your monitor and VGA cable to the VGA output on the KVM, you get nothing? One...
Nov 26, 2025
V
V.Yakob
Hmm... I don't have any other Mac VGA cables. When connecting directly using the cable and adapter, there is an effect, but it is not so...
Nov 26, 2025
Looks to me like a shielding issue. Poorly shielded cables or something internal to the KVM box is letting signals hop/bleed. When you...
Nov 26, 2025
scj312
Have you tried different VGA cables?
Nov 26, 2025
V
V.Yakob
Hey! I have an old 19" Acer AL1917 monitor that I connect to different beige Macintosh. As far as I understand, this monitor should...
Nov 26, 2025
fishgee
I noticed your model number is RODREELSEU. Mine (in US) is just RODREELS without the EU. Is your unit a European one? If so, maybe that...
Nov 26, 2025
G
Grandson
Thank you very much for your replies ThePhage and fishgee! I tested the firmware from 0dan0 (post Oct 22, 2025) v7.1 for both TypeB and...
Nov 26, 2025
fishgee
AFAIK Steve's lookup tool was copied from the Kodak tool and is 2 years old so it doesn't have all the recent serial numbers. I would...
Nov 26, 2025
T
ThePhage
I suspect that newer units are more likely compatible with the C firmware (the unit lookup tool doesn't accurately report on newer...
Nov 26, 2025
T-Man
left a message on
MacEffects
's profile.
I've got you on this....I have 3 Powerbook 180c; multiple years ago entered rabbit hole Powerbook 180c 1 boots OK but the screen has...
Nov 26, 2025
G
Grandson
Hello everyone, I wanted to scan some of my grandfather's 8mm films and was not satisfied with the scan results from the Kodak Reels...
Nov 26, 2025
Peter-Erik
Thanks for information - @anyone suggestions for similar product for Europe?
Nov 26, 2025
