T-Man
Apple Cube G4 Graphics glitch
It was just the video card, switch out some faceplates cards etc and found a working AGP ATI 3d with no glitches
Nov 26, 2025
Stephen
Cracked Hinge on Mac Portable
I am envisioning a perfectly form fitting bracket which is both epoxied and bolted into place — ideally, this will spread the load over...
Nov 26, 2025
@Grandson Try the original firmware from https://mac84.net/8mmlookup/ If that doesn't work, either the unit has failed (return) or...
Nov 26, 2025
P
Paolo B
Agree: without proper reinforcement it will never work for regular use. 3D printing something out of metal seems to be an interesting...
Nov 26, 2025
Best monitor for vintage Macintosh
So if you don't use the adapter and directly connect your monitor and VGA cable to the VGA output on the KVM, you get nothing? One...
Nov 26, 2025
V
V.Yakob
Hmm... I don't have any other Mac VGA cables. When connecting directly using the cable and adapter, there is an effect, but it is not so...
Nov 26, 2025
Looks to me like a shielding issue. Poorly shielded cables or something internal to the KVM box is letting signals hop/bleed. When you...
Nov 26, 2025
scj312
Have you tried different VGA cables?
Nov 26, 2025
V
V.Yakob
Hey! I have an old 19" Acer AL1917 monitor that I connect to different beige Macintosh. As far as I understand, this monitor should...
Nov 26, 2025
fishgee
I noticed your model number is RODREELSEU. Mine (in US) is just RODREELS without the EU. Is your unit a European one? If so, maybe that...
Nov 26, 2025
G
Grandson
Thank you very much for your replies ThePhage and fishgee! I tested the firmware from 0dan0 (post Oct 22, 2025) v7.1 for both TypeB and...
Nov 26, 2025
fishgee
AFAIK Steve's lookup tool was copied from the Kodak tool and is 2 years old so it doesn't have all the recent serial numbers. I would...
Nov 26, 2025
T
ThePhage
I suspect that newer units are more likely compatible with the C firmware (the unit lookup tool doesn't accurately report on newer...
Nov 26, 2025
