Cracked Hinge on Mac Portable
There appears to be some voids on the underside of the subframe assembly (shown in this image on the left side) that could be filled in...
Thursday at 12:35 AM
chuma
Old resistive touchscreen responds, but won't calibrate
Soldering and Repair
I recently acquired what seems to be a real unicorn of a device, a Sharp PT-9000 tablet computer, circa 1994. It's a chunky tablet...
Nov 26, 2025
G
Grandson
Yes, that's right, fishgee, it's a model purchased in the EU. I've now tried various firmware versions, including the ones without the...
Nov 26, 2025
T-Man
Apple Cube G4 Graphics glitch
It was just the video card, switch out some faceplates cards etc and found a working AGP ATI 3d with no glitches
Nov 26, 2025
Stephen
I am envisioning a perfectly form fitting bracket which is both epoxied and bolted into place — ideally, this will spread the load over...
Nov 26, 2025
@Grandson Try the original firmware from https://mac84.net/8mmlookup/ If that doesn't work, either the unit has failed (return) or...
Nov 26, 2025
P
Paolo B
Agree: without proper reinforcement it will never work for regular use. 3D printing something out of metal seems to be an interesting...
Nov 26, 2025
Best monitor for vintage Macintosh
So if you don't use the adapter and directly connect your monitor and VGA cable to the VGA output on the KVM, you get nothing? One...
Nov 26, 2025
V
V.Yakob
Hmm... I don't have any other Mac VGA cables. When connecting directly using the cable and adapter, there is an effect, but it is not so...
Nov 26, 2025
Looks to me like a shielding issue. Poorly shielded cables or something internal to the KVM box is letting signals hop/bleed. When you...
Nov 26, 2025
