O
omega
I'm really sorry. I forgot to write that the file UITRON.BIN needs to be renamed to FWDV280. Big apologies again.
Nov 27, 2025
G
Grandson
Hi omega, good to know that someone else here is still using an EU model. I unzipped the MyFW_H2324148BK00769 folder. It contains two...
Nov 27, 2025
A
ArjenCNX
Test Jig for CC analog/digital boards
Compact Macs
Hi there Tinkerers, thought i'd share something i worked on for a while. Since i started servicing classic mac's, and especially...
Nov 27, 2025
G
Grandson
Thanks 0dan0. Firmware A also tested, without success. See attached screenshots.
Nov 27, 2025
Anyone with a serial connection to Open Firmware able to get PCI info using #50 ? See the attached. Another method to...
Nov 27, 2025
O
omega
Hi, I also have a device from EU. Try using firmware from #511 It works for me.
Nov 27, 2025
@Grandson did you also try Type A? I think if not Type A the screen with remain blank. Is this the first we have seen RODREELSEU on...
Nov 27, 2025
Cracked Hinge on Mac Portable
There appears to be some voids on the underside of the subframe assembly (shown in this image on the left side) that could be filled in...
Nov 27, 2025
chuma
Old resistive touchscreen responds, but won't calibrate
Soldering and Repair
I recently acquired what seems to be a real unicorn of a device, a Sharp PT-9000 tablet computer, circa 1994. It's a chunky tablet...
Nov 26, 2025
G
Grandson
Yes, that's right, fishgee, it's a model purchased in the EU. I've now tried various firmware versions, including the ones without the...
Nov 26, 2025
