  • J
    joevt replied to the thread Cracked Hinge on Mac Portable.
    Tape some paper to the side of the metal drive bracket, install the metal drive bracket, and stuff JB Weld between the fins and the...
  • 0dan0
    Anyone else seeing the jitter appear after the capture started correctly? I have never seen that, so I would like to see examples to...
  • jmacz
    jmacz replied to the thread PowerBook Duo Center Clutch Cover.
    Did not have any layer shift issues. Came out fairly smooth with the only major sanding required being on the end that was attached to...
  • E
    Running C v7.2. Took a gamble and put a 50 year old reel in, about 30m super-8. Loaded in PC, start of clip was excellent. Came out with...
  • K
    kmm replied to the thread G4 Cube VRM.
    Thanks for your helpful information. My VRM components as shown, F1 and F2 as well as C3 and C30, were blown out too and I wonder if...
  • JDW
    JDW replied to the thread PowerBook 100 & 170 owners.
    Steps to Success with Photoshop 1.x 1. Launch the app. 2. CMD-N 3. Set your screen's native resolution (640x400) and click Gray Scale...
  • T-Man
    T-Man replied to the thread PowerBook 100 & 170 owners.
    All of the above are measurements with the on screen ruler just with different units using SuperPaint 1.1, I cannot find any command for...
  • Garrett
    Fun looking support structure! Did you have some trouble with layer shifting during the print?
  • JDW
    Thank you for replying, but I need to clarify when you mean in your second post. What is "575"? You measured 19.5cm diagonally with a...
  • T-Man
    How about this....in the Superpaint 1.1 available window I can see, the ruler when set to "screen dots" is 575 horizontal and and about...
  • T-Man
    Well; on 170 have Superpaint 1.1, MacDraw and MacPaint if there is a way to obtain the information there. Superpaint 1.1 does have an...
  • JDW
    JDW replied to the thread Cracked Hinge on Mac Portable.
    I finished stripping off the chrome paint by hand using mostly a box cutter. I did the sides of the ribs too. My plan was to use...
