  • J
    joevt replied to the thread PowerBook 100 & 170 owners.
    The error may be up to less than an 1/8 of an inch which is not bad since you are measuring in eighths of an inch. bc <<< 'scale=10...
  • muse
    muse replied to the thread Low Voltage Mac Classic When Cold.
    The fluid/electrolyte is conductive. So its a good idea to clean it first before replacing the old capacitors with any new ones.
  • SitesOnFire
    For anyone who finds this page with a similar issue. I've taken the time to desolder large portions of the analog board and resolder the...
  • G
    greenmachine commented on RetroTechTom's profile post.
    What case parts are you in need of? I don't have handles, but I have some other bits.
  • JDW
    JDW replied to the thread Cracked Hinge on Mac Portable.
    @joevt Thank you for your advice! It seems you are suggesting that I do NOT DCM-weld the transparent plastic piece over the backs of...
  • JDW
    JDW replied to the thread PowerBook 100 & 170 owners.
    @T-Man & @joevt ChatGPT is faster than using a calculator when you already have the basic template, which I filled out using the...
  • T-Man
    T-Man replied to the thread PowerBook 100 & 170 owners.
    installed photoshop 2....i cannot find a full screen option; the viewable diagonal on finder is 9 and 7/8 inches. heigh 5 and 2/8ths...
  • J
    The vertical and horizontal resolution also needs to be known to calculate the DPI, but this info can be gathered from the Mac's specs...
  • J
    joevt replied to the thread Cracked Hinge on Mac Portable.
    Tape some paper to the side of the metal drive bracket, install the metal drive bracket, and stuff JB Weld between the fins and the...
  • 0dan0
    Anyone else seeing the jitter appear after the capture started correctly? I have never seen that, so I would like to see examples to...
