PowerBook 100 & 170 owners
Here are a couple of technical tidbits for you... The Macintosh 128 & 512 had 20 bytes of PRAM. The Plus, Mac II, SE, SE/30, IIx, and...
Dec 2, 2025
I think you mean 21.1 cm x 13.1 cm = 8.307 in x 5.157 in = 9.778 in diag = 77.2 dpi cm instead of mm.
Dec 2, 2025
Cracked Hinge on Mac Portable
DCM solvent welded Polycarbonate Rib Reinforcement for Mac Portable
Dec 2, 2025
You would need to drill through the transparent piece and the plastic of the subframe? The alternative to drilling or cutting is...
Dec 2, 2025
I'm not sure which laptop the above measurements apply to. I just hand measured and got: Backlit portable: 21.1 mm x 13.1 mm = 5.157 in...
Dec 2, 2025
Well, I'm actually glad to hear you feel "it's a toss-up" because I already DCM solvent-welded the transparent piece to the back of the...
Dec 2, 2025
I think it would look cleaner without the transparent plastic piece. The JB Weld might perform better if it's thicker but I have no...
Dec 2, 2025
I cannot speak as broadly as "all 68K Portables," but the first trio of MONOCHROME PowerBooks were square corners.
Dec 2, 2025
The error may be up to less than an 1/8 of an inch which is not bad since you are measuring in eighths of an inch. bc <<< 'scale=10...
Dec 2, 2025
muse
Low Voltage Mac Classic When Cold
The fluid/electrolyte is conductive. So its a good idea to clean it first before replacing the old capacitors with any new ones.
Dec 2, 2025
SitesOnFire
For anyone who finds this page with a similar issue. I've taken the time to desolder large portions of the analog board and resolder the...
Dec 2, 2025
