  • JDW
    JDW replied to the thread PowerBook 100 & 170 owners.
    Thank you both for measuring! The spreadsheet is now perfect, I think!
  • David Cook
    David Cook replied to the thread PowerBook 100 & 170 owners.
    I placed a piece of transparency over the screen and marked the corners. I then pulled it off and measured it with a ruler. I am...
  • JDW
    77 DPI for the Mac Portable is expected and matches my Spreadsheet value. But the 84.8 DPI for the PB100 is at odds with the 81 DPI...
  • David Cook
    Yup. It's late. : )
  • David Cook
    Here are a couple of technical tidbits for you... The Macintosh 128 & 512 had 20 bytes of PRAM. The Plus, Mac II, SE, SE/30, IIx, and...
  • J
    joevt replied to the thread PowerBook 100 & 170 owners.
    I think you mean 21.1 cm x 13.1 cm = 8.307 in x 5.157 in = 9.778 in diag = 77.2 dpi cm instead of mm.
  • JDW
    JDW replied to the thread Cracked Hinge on Mac Portable.
    DCM solvent welded Polycarbonate Rib Reinforcement for Mac Portable
  • J
    joevt replied to the thread Cracked Hinge on Mac Portable.
    You would need to drill through the transparent piece and the plastic of the subframe? The alternative to drilling or cutting is...
  • David Cook
    I'm not sure which laptop the above measurements apply to. I just hand measured and got: Backlit portable: 21.1 mm x 13.1 mm = 5.157 in...
  • JDW
    Well, I'm actually glad to hear you feel "it's a toss-up" because I already DCM solvent-welded the transparent piece to the back of the...
  • J
    I think it would look cleaner without the transparent plastic piece. The JB Weld might perform better if it's thicker but I have no...
