rdmark
Macintosh 128k/512k/Plus 240V Analog Board Recap List
I'm recapping a 240V model, and wanted to note here that the stock C33 and C36 are 4700pf Y rated filter caps. The particular...
Dec 2, 2025
rdmark
I've been tinkering with megatron recently actually. The main reason megatron doesn't work with modern netatalk is because AppleSingle...
Dec 2, 2025
Xanadude
Oh ok, gotcha. That makes sense. I flash my phones all the time. This makes me nervous for some reason. 🤞🤞
Dec 2, 2025
Type A, B & C are for slight hardware differences, not for bitrate benefits (same for all.)
Dec 2, 2025
Xanadude
Thanks, Dan! From what I’ve been reading it seems like B is the safer bet for higher bitrates? Sorry about asking so many questions...
Dec 2, 2025
PowerBook 100 & 170 owners
One of the TIL articles you linked to on your spreadsheet discussed the low power ADB mouse. It has an icon of a circle with a flat top...
Dec 2, 2025
This seems to be the same hardware. Type C or B will likely work.
Dec 2, 2025
Xanadude
Thanks for the reply. I appreciate it! On the display, it says 2.0. Is that the same as V2? Our labels on the back seemed to look the...
Dec 2, 2025
techknight
Cracked Hinge on Mac Portable
Very. I have run into it multiple times, and its because the hinges get stiff. 2 reasons. the hinge plastics shrink a bit, causing the...
Dec 2, 2025
techknight
Backlit Portable 5126 — Is your backlight this dim?
That backlight level is normal from what I have seen. Mine is like that, all of the ones I have worked on are like that. Flickering is...
Dec 2, 2025
Restore original Type B firmware, and return that unit as it seems just broken. Likely not a firmware issue as no one else has reported...
Dec 2, 2025
Does it say "V2.0" on the back, or only in the About screen? If the back looks like this: it will be pretty safe to try either Type C...
Dec 2, 2025
Trying to ressurect a Power Macintosh 9600/350
It doesn't damage the RAM to do that. The ANS is the same way and I routinely do a "double reboot" to skip the Long RAM test, which on...
Dec 2, 2025
