The Picture controls in menus are the same. Green tint is also still using left and right arrows, can be done at any time (like before.)...
Dec 3, 2025
S
sheider
@0dan0 Thanks so much for continuing to share the results of your tinkering with this group. Your new settings control with on-screen...
Dec 3, 2025
K
KennyPowers
MicroMac Power Workstation
It's a 4-layer board, where the two internal layers are likely power and ground and the two external layers contain the signal traces...
Dec 3, 2025
Mac84
There is a small chance my A / B / C firmware files got disorganized at some point. I think specifically for the "unmodified" versions...
Dec 3, 2025
FortyTwo
I had no idea something like this ever existed. This is so cool! It's probably pushing that Performa farther than it was ever intended. XD
Dec 3, 2025
T
ThePhage
This sounds wonderful. Do the previous methods of adjusting those settings (White Balance, Tint, Saturation, Frame Rate) still work?
Dec 3, 2025
Cracked Hinge on Mac Portable
Below are photos of mine (before I cleaned out the old grease). What is your technique to removing one of the springs? (And are you...
Dec 3, 2025
techknight
I mean, they are supposed to be stiff to hold up the weight and torsional forces of the entire upper display assembly, but they arent...
Dec 3, 2025
A
ArjenCNX
A Tale of Two Classics
wow, that took a while no doubt! always a joy when they finally do boot up!
Dec 3, 2025
PowerBook 100 & 170 owners
Here’s my low power mouse with the small and light ball that’s really terrible and the normal size connector…
Dec 3, 2025
