The bug is both more minor than I thought and might not be worth improving. The minimum Qp is working to limit the scanner stress...
Dec 4, 2025
You are correct, for some reason 22Mb/s is the lowest, I can get higher bit-rate, but not lower. Found the bug. 7.4.1 shortly
Dec 4, 2025
E
Erwin
My recent observation is that Qp doesnt do anything. It seems to go to highest quality on its own irrespective of the minimum value that...
Dec 4, 2025
I've updated the Type C download (above) to have the updated folder name. Unfortunately there is nothing in the build that changes the...
Dec 4, 2025
E
Erwin
Flashed the above 7.4, boot screen says 7.4, folder name is FilmScnC7.3. Set the Qp to 23 min, sharpness -1, loaded a reel, scanned for...
Dec 4, 2025
Cracked Hinge on Mac Portable
Ah yes, Kai! You mean this brilliant fellow... But of course, a 3D CAD genius like him would be need for reproducing the entire...
Dec 4, 2025
At this point it might be an idea to reach out to polymatt on YouTube...
Dec 4, 2025
Found photos of another person's broken right-side hinge holder. Poor guy tried and failed with 3 screws! 😯 If we can eliminate...
Dec 4, 2025
I decided to cut a little triangular-shaped piece from my transparent Polycarbonate resin board to solvent weld over one spot that was...
Dec 4, 2025
