Try my test of many short captures. If my units is 9% error rate, but your closer 50%, that is different might be setup, reel skid...
Dec 5, 2025
MeTheMac
iBook G3 Clamshell display replacement failure, a cautionary tale
Huh. I guess this is what happened to my magically stopped working clamshell after I swapped the screens from an Indigo one...
Dec 5, 2025
Could you clip the arms off the connector so you could insert it the proper way? Of course, that assumes all the pins are actually the...
Dec 5, 2025
That is correct for this version, but in the next it will be simply threshold limited.
Dec 5, 2025
T
ThePhage
@0dan0 small bit of feedback on 7.4 (C). I'm not sure you designed it this way or not, but during capture, while adjusting the Qp, if I...
Dec 5, 2025
E
Erwin
I checked my scans of this latest reel of film, 4 scans of about 700 - 900 MB each. Two are okay, two are wrong. I cant see a flash on...
Dec 5, 2025
Golden Griffin
updated their
status
Getting back into a hobby I absolutely loved and regretfully stepped away from. A Mac owner since 1989.
Dec 5, 2025
Backlit Portable 5126 — Is your backlight this dim?
Here are measurements I made today. Just FYI, for those of you who appreciate FYI's, that is. :-) Between Metal Inner Edges (see...
Dec 5, 2025
